Bilinearized Legendrian contact homology and the augmentation category - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Symplectic Geometry Année : 2014
In this paper, we construct an A ∞-category associated to a Legen-drian submanifold of a jet space. Objects of the category are augmentations of the Chekanov algebra A(Λ) and the homology of the morphism spaces forms a new set of invariants of Legendrian submanifolds called the bilinearized Legendrian contact homology. Those are constructed as a generalization of linearized Legendrian contact homology using two augmentations instead of one. Considering similar constructions with more augmentations leads to the higher order composition maps in the category and generalizes the idea of [6] where an A ∞-algebra was constructed from one augmentation. This category allows us to define a notion of equivalence of augmentations when the coefficient ring is a field regardless of its characteristic. We use simple examples to show that bilinearized cohomology groups are efficient to distinguish those equivalences classes. We also generalize the duality exact sequence from [12] in our context, and interpret geometrically the bilinearized homology in terms of the Floer homology of Lagrangian fillings (following [8]).
Bilinearisation_final.pdf (280.43 Ko) Télécharger le fichier
hal-01135638 , version 1 (25-03-2015)
hal-01135638 , version 2 (25-03-2015)
Frédéric Bourgeois, Baptiste Chantraine. Bilinearized Legendrian contact homology and the augmentation category. Journal of Symplectic Geometry, 2014, 12 (3), pp.553-583. ⟨10.4310/JSG.2014.v12.n3.a5⟩. ⟨hal-01135638v2⟩
362 Consultations
142 Téléchargements
