Impact: an Unreliable Failure Detector Based on Processes' Relevance and the Confidence Degree in the System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2015
This technical report presents a new and flexible unreliable failure detector, denoted Impact Failure Detector (FD), whose output gives the trust level of a set of processes. By expressing the relevance of each node by an impact factor value as well as an acceptable margin of failure in the system, the Impact FD enables the user to tune the failure detection configuration in accordance with the requirements of the application: in some scenarios, the failure of low impact or redundant nodes does not jeopardize the confidence in the system, while the crash resulting from a high impact factor may seriously affect it. Either a softer or stricter monitoring is thus possible.
Impact_TechReport_hal-01136595.pdf (1.2 Mo) Télécharger le fichier
hal-01136595 , version 1 (30-03-2015)
hal-01136595 , version 2 (14-04-2015)
hal-01136595 , version 3 (08-09-2016)
  • HAL Id : hal-01136595 , version 2
Anubis G. M. Rossetto, Luciana Arantes, Pierre Sens, Claudio R. Geyer. Impact: an Unreliable Failure Detector Based on Processes' Relevance and the Confidence Degree in the System. [Research Report] Université Pierre et Marie Curie; INRIA Paris-Rocquencourt - Regal; Universidade Federal do Rio Grande do Sul. 2015. ⟨hal-01136595v2⟩
237 Consultations
201 Téléchargements
