Le Tour de France 2014 at a Glance
Our visualization shows the temporal evolution of " Le Tour de France 2014 " cyclists ranking after each stage. In contrast to standard snapshot ranking tables used to represent this ranking, our visualization clearly shows the temporal evolution of each cyclist's ranking and global trends for each stage. Moreover, our layout algorithm 1) ensures no overlap, tied cyclists at a given stage being adjacent instead of superimposed; and 2) conveys the gap magnitudes between cyclists: the larger the white space between cyclists, the further they are. Additionally, thin gray lines represent gaps of 1 minute. Color encodes cyclist's nationality and stage miniatures provide context on the top of the visualization. For example, we see that the second stage was a key stage, involving many changes. Then the ranking remained stable for two stages, before changing again. We also observe that gap magnitudes increase with time; that flat stages do not impact the rankings neither the gap magnitudes much, whereas stages in mountain strongly impact both; and the expert eye will see that Valverde lost his second position three stages before the end of the race, and that Porte constantly decreased in ranking during high mountain stages, while he was ranked second.
Interface homme-machine [cs.HC]
VIS_2014_vpg_contest_TDF.pdf (65.59 Ko)
Télécharger le fichier
VIS_2014_vpg_contest_TDF-poster.pdf (8.22 Mo)
