Delay-Dependent Positivity: Application to Interval Observers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
New delay-dependent conditions of positivity for linear systems with time-varying delays are introduced. These conditions are applied to interval observer design for systems with time-varying delays in the state equations and in the measurements.
ECC15_0474_FI.pdf (635.43 Ko) Télécharger le fichier
hal-01140336 , version 1 (08-04-2015)
  • HAL Id : hal-01140336 , version 1
Denis Efimov, Andrey Polyakov, Emilia Fridman, Wilfrid Perruquetti, Jean-Pierre Richard. Delay-Dependent Positivity: Application to Interval Observers. Proc. ECC'15, Jul 2015, Linz, Austria. ⟨hal-01140336⟩
172 Consultations
621 Téléchargements
