FECFRAMEv2: Adding Sliding Encoding Window Capabilities to the FEC Framework: Problem Position - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2016
The Forward Error Correction (FEC) Framework (or FECFRAME) (RFC 6363) has been defined by the FECFRAME IETF WG to enable the use of FEC Encoding with real-time flows in a flexible manner. The original FECFRAME specification only considers the use of block FEC codes, wherein the input flow(s) is(are) segmented into a sequence of blocks and FEC encoding performed independently on a per-block basis. This document discusses an extension of FECFRAME in order to enable a sliding (potentially elastic) window encoding of the input flow(s), using convolutional FEC codes for the erasure channel, as an alternative to block FEC codes.
draft-roca-nwcrg-fecframev2-problem-position-02.pdf (60.31 Ko) Télécharger le fichier
hal-01141470 , version 1 (13-04-2015)
hal-01141470 , version 2 (19-07-2015)
hal-01141470 , version 3 (24-05-2016)
  • HAL Id : hal-01141470 , version 3
Vincent Roca. FECFRAMEv2: Adding Sliding Encoding Window Capabilities to the FEC Framework: Problem Position. 2016, pp.18. ⟨hal-01141470v3⟩
172 Consultations
168 Téléchargements
