High-Frequency Shadows for Real-Time Rendering of Trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of graphics tools Année : 2010
We present a fast and simple method for adding high-frequency shadows into the foliage of trees rendered in real-time. When leaves of a tree project shadows onto other leaves, determining the relationships between cast shadows and the corresponding occluders is a visually difficult task. We present a method based on this assumption to quickly determine shadows cast by leaves onto other leaves. To this end, we simulate the presence of these shadows rather than projecting them exactly. The characteristics of these simulated shadows (movement, parallax, size, softness, and color) evolve realistically when the lighting conditions change. Our method is fast and supports soft shadows.
Fichier non déposé
hal-01143381 , version 1 (17-04-2015)
Kevin Boulanger, Kadi Bouatouch, Sumanta Pattanaik. High-Frequency Shadows for Real-Time Rendering of Trees . Journal of graphics tools, 2010, 15 (1), pp.1-12. ⟨10.1080/2151237X.2010.10390648⟩. ⟨hal-01143381⟩
181 Consultations
0 Téléchargements
