Rewriting Strategies and Strategic Rewrite Programs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2015
Hélène Kirchner
Connectez-vous pour contacter l'auteur
This survey aims at providing unified definitions of strategies, strategic rewriting and strategic programs. It gives examples of main constructs and languages used to write strategies. It also explores some properties of strategic rewriting and operational semantics of strategic programs. Current research topics are identified.
HK-RewStrat.pdf (587.04 Ko) Télécharger le fichier
hal-01143486 , version 1 (17-04-2015)
hal-01143486 , version 2 (11-08-2015)
  • HAL Id : hal-01143486 , version 2
Hélène Kirchner. Rewriting Strategies and Strategic Rewrite Programs. Logic, Rewriting, and Concurrency (LRC 2015). Festschrift Symposium in Honor of Jos\'e Meseguer, Urbana, Illinois, USA, September 23-25, 2015,, 2015. ⟨hal-01143486v2⟩
Collections
INRIA INRIA2
245 Consultations
680 Téléchargements
