Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Journal articles
Multicriteria shape design of an aerosol can
Abstract : One of the current challenges in the domain of the multicriteria shape optimization is to reduce the calculation time required by conventional methods. The high computational cost is due to the high number of simulation or function calls required by these methods. Recently, several studies have been led to overcome this problem by integrating a metamodel in the overall optimization loop. In this paper, we perform a coupling between the Normal Boundary Intersection – NBI – algorithm with Radial Basis Function – RBF – metamodel in order to have a simple tool with a reasonable calculation time to solve multicriteria optimization problems. First, we apply our approach to academic test cases. Then, we validate our method against an industrial case, namely, shape optimization of the bottom of an aerosol can undergoing nonlinear elasto-plastic deformation. Then, in order to select solutions among the Pareto efficient ones, we use the same surrogate approach to implement a method to compute Nash and Kalai–Smorodinsky equilibria.
Complete list of metadata
https://hal.inria.fr/hal-01144269
Contributor : Abderrahmane Habbal Connect in order to contact the contributor
Submitted on : Tuesday, April 21, 2015 - 1:18:10 PM
Last modification on : Saturday, June 25, 2022 - 11:16:30 PM
Links full text
Identifiers
Citation
Aalae Benki, Abderrahmane Habbal, Gaël Mathis, Olivier Beigneux. Multicriteria shape design of an aerosol can. Journal of Computational Design and Engineering, Elsevier 2015, pp.11. ⟨10.1016/j.jcde.2015.03.003⟩. ⟨hal-01144269⟩
Share
Metrics
Record views
96
