STRONG-VISCOSITY SOLUTIONS: SEMILINEAR PARABOLIC PDEs AND PATH-DEPENDENT PDEs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
Francesco Russo
The aim of the present work is the introduction of a viscosity type solution, called strong-viscosity solution to distinguish it from the classical one, with the following peculiarities: it is a purely analytic object; it can be easily adapted to more general equations than classical partial differential equations. First, we introduce the notion of strong-viscosity solution for semilinear parabolic partial differential equations, defining it, in a few words, as the pointwise limit of classical solutions to perturbed semilinear parabolic partial differential equations; we compare it with the standard definition of viscosity solution. Afterwards, we extend the concept of strong-viscosity solution to the case of semilinear parabolic path-dependent partial differential equations, providing an existence and uniqueness result.
ComparisonViscosityOsaka2017_AcceptedDecember.pdf (423.03 Ko) Télécharger le fichier
hal-01145301 , version 1 (23-04-2015)
hal-01145301 , version 2 (17-11-2018)
hal-01145301 , version 3 (08-03-2019)
  • HAL Id : hal-01145301 , version 2
Andrea Cosso, Francesco Russo. STRONG-VISCOSITY SOLUTIONS: SEMILINEAR PARABOLIC PDEs AND PATH-DEPENDENT PDEs. 2018. ⟨hal-01145301v2⟩
249 Consultations
436 Téléchargements
