Weighted Homogeneity for Time-Delay Systems: Finite-Time and Independent of Delay Stability - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
Global delay independent stability is analyzed for nonlinear time-delay systems by applying homogeneity theory. It is shown that finite-time stability can be encountered in this class of systems under uniformity of the convergence time with respect to delay. Some additional tools for stability analysis of time-delay systems using homogeneity are also presented: in particular, it is shown that if a time-delay system is homogeneous with nonzero degree and it is globally asymptotically stable for some delay, then this property is preserved for any delay value, which is known as the independent of delay (IOD) stability.
FTS_time_delay_6p.pdf (313.08 Ko) Télécharger le fichier
hal-01145321 , version 1 (27-04-2015)
hal-01145321 , version 2 (15-05-2015)
  • HAL Id : hal-01145321 , version 1
Denis Efimov, Andrey Polyakov, Wilfrid Perruquetti, Jean-Pierre Richard. Weighted Homogeneity for Time-Delay Systems: Finite-Time and Independent of Delay Stability. 2015. ⟨hal-01145321v1⟩
301 Consultations
582 Téléchargements
