Building Efficient and Compact Data Structures for Simplicial Complexes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The Simplex Tree (ST) is a recently introduced data structure that can represent abstract simplicial complexes of any dimension and allows efficient implementation of a large range of basic operations on simplicial complexes. In this paper, we show how to optimally compress the Simplex Tree while retaining its functionalities. In addition, we propose two new data structures called Maximal Simplex Tree (MxST) and Simplex Array List (SAL). We analyze the compressed Simplex Tree, the Maximal Simplex Tree, and the Simplex Array List under various settings.
simplexsocg.pdf (663.65 Ko) Télécharger le fichier
Format : Figure, Image
hal-01145407 , version 1 (27-04-2015)
Jean-Daniel Boissonnat, C. S. Karthik, Sébastien Tavenas. Building Efficient and Compact Data Structures for Simplicial Complexes. International Symposium on Computational Geometry 2015, Jun 2015, Eindhoven, Netherlands. ⟨10.4230/LIPIcs.SOCG.2015.642⟩. ⟨hal-01145407⟩
193 Consultations
346 Téléchargements
