myMed: an ad hoc Framework for Executing Homogeneous Open Social Networks
myMed is an experimental framework for implementing and deploying, on the top of a built-in cloud platform, many Open Social Networks (OSN) that could take advantage of sharing common software modules, hardware ressources, making inter-communication and inter-interaction simpler and improving rapid development. This paper discuss the main advantages in coordinating and communicating different OSN built and hosted on the same framework and platform.
