A syntactic soundness proof for free-variable tableaux with on-the-fly Skolemization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
We prove the syntactic soundness of classical tableaux with free variables and on-the-fly Skolemization. Soundness proofs are usually built from semantic arguments, and this is to our knowledge, the first proof that appeals to syntactic means. We actually prove the soundness property with respect to cut-free sequent calculus. This requires great care because of the additional liberty in freshness checking allowed by the use of Skolem terms. In contrast to semantic soundness, we gain the possibility to state a cut elimination theorem for sequent calculus, under the proviso that completeness of the method holds. We believe that such techniques can be applied to tableaux in other logics as well.
main.pdf (337.26 Ko) Télécharger le fichier
hal-01154799 , version 1 (23-05-2015)
Richard Bonichon, Olivier Hermant. A syntactic soundness proof for free-variable tableaux with on-the-fly Skolemization. 2015. ⟨hal-01154799⟩
212 Consultations
593 Téléchargements
