Evolution Strategies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2015
Dirk V. Arnold
  • Fonction : Auteur
  • PersonId : 874065
Anne Auger
  • Fonction : Auteur
  • PersonId : 751513
  • IdHAL : anne-auger
Evolution strategies are evolutionary algorithms that date back to the 1960s and that are most commonly applied to black-box optimization problems in continuous search spaces. Inspired by biological evolution, their original formulation is based on the application of mutation, recombination and selection in populations of candidate solutions. From the algorithmic viewpoint, evolution strategies are optimization methods that sample new candidate solutions stochastically, most commonly from a multivariate normal probability distribution. Their two most prominent design principles are unbiasedness and adaptive control of parameters of the sample distribution. In this overview the important concepts of success based step-size control, self-adaptation and derandomization are covered, as well as more recent developments like covariance matrix adaptation and natural evolution strategies. The latter give new insights into the fundamental mathematical rationale behind evolution strategies. A broad discussion of theoretical results includes progress rate results on various function classes and convergence proofs for evolution strategies.
es-overview-2015.pdf (869.75 Ko) Télécharger le fichier
hal-01155533 , version 1 (09-08-2016)
  • HAL Id : hal-01155533 , version 1
Nikolaus Hansen, Dirk V. Arnold, Anne Auger. Evolution Strategies. Janusz Kacprzyk; Witold Pedrycz. Handbook of Computational Intelligence, 871-898, Springer, 2015, 978-3-622-43504-5. ⟨hal-01155533⟩
345 Consultations
1780 Téléchargements
