Data-aware Process Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2015
This report presents the Data-aware Process Networks, a new parallel execution model adapted to the hardware constraints of high-level synthesis, where the data transferts are made explicit. We show that the DPN model is consistant in the meaning where any translation of a sequential program produces an equivalent DPN without deadlocks. Finally, we show how to compile a sequential program to a DPN and how to optimize the input/output and the parallelism.
RR-8735.pdf (936.57 Ko) Télécharger le fichier
hal-01158726 , version 1 (01-06-2015)
  • HAL Id : hal-01158726 , version 1
Christophe Alias, Alexandru Plesco. Data-aware Process Networks. [Rapport de recherche] RR-8735, Inria - Research Centre Grenoble – Rhône-Alpes; INRIA. 2015, pp.32. ⟨hal-01158726⟩
598 Consultations
154 Téléchargements
