Semidefinite and Spectral Relaxations for Multi-Label Classification - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Preprints, Working Papers, ... Year : 2015
In this paper, we address the problem of multi-label classification. We consider linear classifiers and propose to learn a prior over the space of labels to directly leverage the performance of such methods. This prior takes the form of a quadratic function of the labels and permits to encode both attractive and repulsive relations between labels. We cast this problem as a structured prediction one aiming at optimizing either the accuracies of the predictors or the F 1-score. This leads to an optimization problem closely related to the max-cut problem, which naturally leads to semidefinite and spectral relaxations. We show on standard datasets how such a general prior can improve the performances of multi-label techniques.
lajugie14semidefinite.pdf (177.91 Ko) Télécharger le fichier
Dates and versions
hal-01159321 , version 1 (03-06-2015)
Identifiers
Cite
Rémi Lajugie, Piotr Bojanowski, Sylvain Arlot, Francis Bach. Semidefinite and Spectral Relaxations for Multi-Label Classification. 2015. ⟨hal-01159321⟩
232 View
80 Download
Share
