Homogenization of materials with sign changing coefficients - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
We investigate a periodic homogenization problem involving two isotropic materials with conductivities of different signs: a classical material and a metamaterial (or negative material). Combining the T−coercivity approach and the unfolding method for homogenization, we prove well-posedness results for the initial and the homogenized problems and we obtain a convergence result. These results are obtained under the condition that the contrast between the two conductivities is large enough in modulus. The homogenized matrix, is generally anisotropic and indefinite, but it is shown to be isotropic and (positive or negative) definite for particular geometries having symmetries.
A_HOMOG_METAMAT_Revised.pdf (424.71 Ko) Télécharger le fichier
hal-01162225 , version 1 (09-06-2015)
hal-01162225 , version 2 (10-09-2015)
hal-01162225 , version 3 (25-09-2015)
hal-01162225 , version 4 (13-04-2016)
  • HAL Id : hal-01162225 , version 2
Renata Bunoiu, Karim Ramdani. Homogenization of materials with sign changing coefficients. 2015. ⟨hal-01162225v2⟩
537 Consultations
651 Téléchargements
