Iterative methods for scattering problems in unbounded elastic waveguides - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Wave Motion Année : 2016
We consider the time-harmonic problem of the diffraction of an incident propagative mode by a localized defect, in an infinite straight isotropic elastic waveguide. We propose several iterative algorithms to compute an approximate solution of the problem, using a classical finite element discretization in a small area around the perturbation, and a modal expansion in unbounded straight parts of the guide. Each algorithm can be related to a so-called domain decomposition method, with or without an overlap between the domains. Specific transmission conditions are used, so that only the sparse finite element matrix has to be inverted, the modal expansion being obtained by a simple projection, using the Fraser bi-orthogonality relation. The benefit of using an overlap between the finite element domain and the modal domain is emphasized, in particular for the extension to the anisotropic case. The transparency of these new boundary conditions is checked for two- and three-dimensional anisotropic waveguides. Finally, in the isotropic case, numerical validation for two- and three-dimensional waveguides illustrates the efficiency of the new approach, compared to other existing methods, in terms of number of iterations and CPU time.
article_submitted_150617.pdf (3.1 Mo) Télécharger le fichier
hal-01164794 , version 1 (17-06-2015)
hal-01164794 , version 2 (19-06-2015)
hal-01164794 , version 3 (19-02-2016)
  • HAL Id : hal-01164794 , version 2
Vahan Baronian, Anne-Sophie Bonnet-Ben Dhia, Sonia Fliss, Antoine Tonnoir. Iterative methods for scattering problems in unbounded elastic waveguides. Wave Motion, 2016. ⟨hal-01164794v2⟩
421 Consultations
418 Téléchargements
