Flexible Multi-layer Sparse Approximations of Matrices and Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
The computational cost of many signal processing and machine learning techniques is often dominated by the cost of applying certain linear operators to high-dimensional vectors. This paper introduces an algorithm aimed at reducing the complexity of applying linear operators in high dimension by approximately factorizing the corresponding matrix into few sparse factors. The approach relies on recent advances in non-convex optimization. It is first explained and analyzed in details and then demonstrated experimentally on various problems including dictionary learning for image denoising, and the approximation of large matrices arising in inverse problems.
ieeeJSTSP_hal.pdf (961.91 Ko) Télécharger le fichier
hal-01167948 , version 1 (25-06-2015)
hal-01167948 , version 2 (29-03-2016)
Luc Le Magoarou, Rémi Gribonval. Flexible Multi-layer Sparse Approximations of Matrices and Applications. 2015. ⟨hal-01167948v1⟩
1532 Consultations
1386 Téléchargements
