CELLS AND CACTI - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
CELLS AND CACTI
Let $(W,S)$ be a Coxeter system, let $\ph$ be a weight function on $S$ and let $\cactus_W$ denote the associated {\it cactus group}. Following an idea of I. Losev, we construct an action of $\cactus_W \times \cactus_W$ on $W$ which has nice properties with respect to the partition of $W$ into left, right or two-sided cells (under some hypothesis, which hold for instance if $\ph$ is constant or if $W$ is finite of rank $\le 4$). It must be noticed that the action depends heavily on $\ph$.
cactus.equal.pdf (134.42 Ko) Télécharger le fichier
hal-01168198 , version 1 (25-06-2015)
hal-01168198 , version 2 (30-08-2015)
hal-01168198 , version 3 (15-10-2015)
Cédric Bonnafé. CELLS AND CACTI. 2015. ⟨hal-01168198v1⟩
126 Consultations
130 Téléchargements
