Memetic Semantic Genetic Programming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Robyn Ffrancon
  • Fonction : Auteur
  • PersonId : 967892
Marc Schoenauer
Semantic Backpropagation (SB) was introduced in GP so as to take into account the semantics of a GP tree at all intermediate states of the program execution, i.e., at each node of the tree. The idea is to compute the optimal " should-be " values each subtree should return, whilst assuming that the rest of the tree is unchanged, so as to minimize the fitness of the tree. To this end, the Random Desired Output (RDO) mutation operator, proposed in [17], uses SB in choosing, from a given library, a tree whose semantics are preferred to the semantics of a randomly selected subtree from the parent tree. Pushing this idea one step further, this paper introduces the Local Tree Improvement (LTI) operator, which selects from the parent tree the overall best subtree for applying RDO, using a small randomly drawn static library. Used within a simple Iterated Local Search framework, LTI can find the exact solution of many popular Boolean benchmarks in reasonable time whilst keeping solution trees small, thus paving the road for truly memetic GP algorithms.
newGECCO.pdf (693.7 Ko) Télécharger le fichier
8parV_errors_old_vs_new.pdf (62.3 Ko) Télécharger le fichier
all_times_v3.pdf (36.76 Ko) Télécharger le fichier
all_times_v5.pdf (390.84 Ko) Télécharger le fichier
hal-01169074 , version 1 (27-06-2015)
  • HAL Id : hal-01169074 , version 1
Robyn Ffrancon, Marc Schoenauer. Memetic Semantic Genetic Programming. Genetic and Evolutionary Computation COnference (GECCO 2015), Jul 2015, Madrid, Spain. pp.1023-1030. ⟨hal-01169074⟩
287 Consultations
984 Téléchargements
