Greedy Semantic Local Search for Small Solutions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Robyn Ffrancon
  • Fonction : Auteur
  • PersonId : 967892
Marc Schoenauer
Semantic Backpropagation (SB) was introduced in GP so as to take into account the semantics of a GP tree at all intermediate states of the program execution, i.e., at each node of the tree. The idea is to compute the optimal " should-be " values each subtree should return, whilst assuming that the rest of the tree is unchanged, and to choose a subtree that matches as well as possible these target values. A single tree is evolved by iteratively replacing one of its nodes with the best subtree from a static library according to this local fitness, with tree size as a secondary criterion. Previous results for standard Boolean GP benchmarks that have been obtained by the authors with another variant of SB are improved in term of tree size. SB is then applied for the first time to categorical GP benchmarks, and outperforms all known results to date for three variable finite algebras.
semantic_workshop_gecco2015.pdf (961.56 Ko) Télécharger le fichier
boolean_tree_size_glti_vs_lti_withCmp08_v2.pdf (370.06 Ko) Télécharger le fichier
categorical_num_ops_glti_vs_lti_v2.pdf (373.55 Ko) Télécharger le fichier
hal-01169075 , version 1 (30-06-2015)
  • HAL Id : hal-01169075 , version 1
Robyn Ffrancon, Marc Schoenauer. Greedy Semantic Local Search for Small Solutions. Companion Proceedings (workshops) of the Genetic and Evolutionary Computation COnference, Jul 2015, TAO, INRIA Saclay, France. pp.1293-1300. ⟨hal-01169075⟩
162 Consultations
288 Téléchargements
