ON THE HALPHEN TRANSFORM OF ALGEBRAIC SPACE CURVES - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
The Halphen transform of a plane curve is the curve obtained by intersecting the tangent lines of the curve with the corresponding polar lines with respect to some conic. This transform has been introduced by Halphen as a branch desingularization method and has also been studied by Coolidge and by Josse. We extend this notion to Halphen transform of a space curve and study several of its properties (birationality, degree, rank, class, desingularization).
ajfp_halphen150629.pdf (237.98 Ko) Télécharger le fichier
hal-01169662 , version 1 (30-06-2015)
Alfrederic Josse, Françoise Pene. ON THE HALPHEN TRANSFORM OF ALGEBRAIC SPACE CURVES. 2015. ⟨hal-01169662⟩
158 Consultations
141 Téléchargements
