A Variational EM Algorithm for the Separation of Moving Sound Sources
This paper addresses the problem of separation of moving sound sources. We propose a probabilistic framework based on the complex Gaussian model combined with non-negative matrix factoriza-tion. The properties associated with moving sources are modeled using time-varying mixing filters described by a stochastic temporal process. We present a variational expectation-maximization (VEM) algorithm that employs a Kalman smoother to estimate the mixing filters. The sound sources are separated by means of Wiener filters, built from the estimators provided by the proposed VEM algorithm. Preliminary experiments with simulated data show that, while for static sources we obtain results comparable with the base-line method of Ozerov et al., in the case of moving source our method outperforms a piece-wise version of the baseline method.
