Licenses Compatibility and Composition in the Web of Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The absence of clarity concerning the licensing terms does not encourage the reuse of the data by the consumers, thus preventing further publication and consumption of datasets, at the expense of the growth of the Web of Data itself. In this paper, we propose a general framework to attach the licensing terms to the data queried on the Web of Data. In particular, our framework addresses the following issues: (i) the various license schemas are collected and aligned taking as reference the Creative Commons schema, (ii) the compatibility of the licensing terms concerning the data affected by the query is verified, and (iii) if compatible, the licenses are combined into a composite license. The framework returns the composite license as licensing term about the data resulting from the query.
VillataAndGandon_COLD2012.pdf (530.65 Ko) Télécharger le fichier
hal-01171125 , version 1 (02-07-2015)
  • HAL Id : hal-01171125 , version 1
Serena Villata, Fabien Gandon. Licenses Compatibility and Composition in the Web of Data. Third International Workshop on Consuming Linked Data (COLD2012), Nov 2012, Boston, United States. ⟨hal-01171125⟩
369 Consultations
171 Téléchargements
