Simulation of life distributions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2015
This chapter introduces the principles underlying the simulation of the probability distributions which typically characterize the life/failure processes of engineered components and systems. The basic procedures for sampling random numbers are reviewed and examples are provided with reference to the uniform, exponential and Weibull distributions which are among the most commonly used probability distributions in reliability, availability and safety analysis.
eqr471 Simulation of life distributions - revised clean.pdf (535.28 Ko) Télécharger le fichier
hal-01171476 , version 1 (04-07-2015)
Enrico Zio. Simulation of life distributions. Wiley StatsRef: Statistics Reference Online, 2015, ⟨10.1002/9781118445112.stat03882.pub2⟩. ⟨hal-01171476⟩
126 Consultations
195 Téléchargements
