Data assimilation for linear parabolic equations: minimax projection method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Scientific Computing Année : 2015
In this paper we propose a state estimation method for linear parabolic partial differential equations (PDE) that accounts for errors in the model, truncation, and observations. It is based on an extension of the Galerkin projection method. The extended method models projection coefficients, representing the state of the PDE in some basis, by means of a differential-algebraic equation (DAE). The original estimation problem for the PDE is then recast as a state estimation problem for the constructed DAE using a linear continuous minimax filter. We construct a numerical time integrator that preserves the monotonic decay of a nonstationary Lyapunov function along the solution. To conclude, we demonstrate the efficacy of the proposed method by applying it to the tracking of a discharged pollutant slick in a two-dimensional fluid.
Zhuk-SIAM-2015.pdf (2.34 Mo) Télécharger le fichier
hal-01174081 , version 1 (08-07-2015)
Sergiy Zhuk, Frank Jason, Isabelle Herlin, Robert Shorten. Data assimilation for linear parabolic equations: minimax projection method. SIAM Journal on Scientific Computing, 2015, 37 (3), pp.A1174-A1196. ⟨10.1137/13094709X⟩. ⟨hal-01174081⟩
112 Consultations
155 Téléchargements
