Understanding and Improving Reformulation-Based Query Answering Performance in RDF - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Answering queries over Semantic Web data, i.e., RDF graphs, must account for both explicit and implicit data, entailed by the explicit data and the semantic constraints holding on them. Two main query answering techniques have been devised, namely Saturation-based (Sat) which precomputes and adds to the graph all implicit information, and Reform-ulation-based (Ref) which reformulates the query based on the graph constraints, so that evaluating the reformulated query directly against the explicit data (i.e., without considering the constraints) produces the query answer. While Sat is well known, Ref has received less attention so far. In particular, reformulated queries often perform poorly if the query is complex. Our demonstration [6] show-cases a large set of Ref techniques, including but not limited to one we proposed recently [5]. The audience will be able to 1. test them against different datasets, constraints and queries, as well as different well-established systems, 2. analyze and understand the performance challenges they raise, and 3. alter the scenarios to visualize the impact on performance. In particular, we show how a cost-based Ref approach allows avoiding reformulation performance pitfalls.
RDFCoversDemo.pdf (764.75 Ko) Télécharger le fichier
hal-01174299 , version 1 (08-07-2015)
  • HAL Id : hal-01174299 , version 1
Damian Bursztyn, François Goasdoué, Ioana Manolescu. Understanding and Improving Reformulation-Based Query Answering Performance in RDF. BDA'15, Sep 2015, Île de Porquerolles, France. ⟨hal-01174299⟩
600 Consultations
194 Téléchargements
