Progressive Current Source Models in Magnetic Vector Potential Finite Element Formulations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Progressive refinements of the current sources in magnetic vector potential finite element formulations are done with a subproblem method. The sources are first considered via magnetomotive force or Biot-Savart models up to their volume finite element models, from statics to dynamics. A novel way to define the source fields is proposed to lighten the computational efforts, via the conversion of the common volume sources to surface sources, with no need of any pre-resolution. Accuracy improvements are then efficiently obtained for local currents and fields, and global quantities, i.e. inductances, resistances, Joule losses and forces.
OA2-1 Dular-Progressive Current Source Models in Magnetic Vector Potential Finite Element Formulations.pdf (801.44 Ko) Télécharger le fichier
hal-01174978 , version 1 (31-08-2015)
  • HAL Id : hal-01174978 , version 1
Patrick Dular, Patrick Kuo-Peng, Mauricio Valencia Ferreira da Luz, Laurent Krähenbühl. Progressive Current Source Models in Magnetic Vector Potential Finite Element Formulations. Compumag 2015, Jun 2015, Montréal, Canada. pp.648. ⟨hal-01174978⟩
327 Consultations
155 Téléchargements
