TRIFL: A Generic Trajectory Index for Flash Storage - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Algorithms Année : 2015
Due to several important features, such as high performance, low power consumption, and shock resistance, NAND flash has become a very popular stable storage medium for embedded mobile devices, personal computers, and even enterprise servers. However, the peculiar characteristics of flash memory require redesigning the existing data storage and indexing techniques that were devised for magnetic hard disks. In this article, we propose TRIFL, an efficient and generic TRajectory Index for FLash. TRIFL is designed around the key requirements of trajectory indexing and flash storage. TRIFL is generic in the sense that it is efficient for both simple flash storage devices such as SD cards and more powerful devices such as solid state drives. In addition, TRIFL is supplied with an online self-tuning algorithm that allows adapting the index structure to the workload and the technical specifications of the flash storage device to maximize the index performance. Moreover, TRIFL achieves good performance with relatively low memory requirements, which makes the index appropriate for many application scenarios. The experimental evaluation shows that TRIFL outperforms the representative indexing methods on magnetic disks and flash disks.
Informatique
Fichier non déposé
hal-01176563 , version 1 (15-07-2015)
Dai Hai Ton That, Iulian Sandu-Popa, Karine Zeitouni. TRIFL: A Generic Trajectory Index for Flash Storage. ACM Transactions on Algorithms, 2015, 1 (2), 44 p. ⟨10.1145/2786758⟩. ⟨hal-01176563⟩
113 Consultations
0 Téléchargements
