On the computation of the Möbius transform - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
The Möbius transform is a crucial transformation into the Boolean world; it allows to change the Boolean representation between the True Table and Algebraic Normal Form. In this work, we introduce a new algebraic point of view of this transformation based on the polynomial form of Boolean functions. It appears that we can perform a new notion: the Möbius computation variable by variable and new computation properties. As a consequence, we propose new algorithms which can produce a huge speed up of the Möbius computation for sub-families of Boolean function. Furthermore we compute directly the Möbius transformation of some particular Boolean functions. Finally, we show that for some of them the Hamming weight is directly related to the algebraic degree of specific factors.
Fast_Mobius_computation.pdf (384.16 Ko) Télécharger le fichier
hal-01178356 , version 1 (19-07-2015)
hal-01178356 , version 2 (08-07-2019)
hal-01178356 , version 3 (15-04-2020)
Paternité
Morgan Barbier, Hayat Cheballah, Jean-Marie Le Bars. On the computation of the Möbius transform. 2015. ⟨hal-01178356v2⟩
246 Consultations
792 Téléchargements
