Contracts for Systems Design: Methodology and Application cases
Recently, contract based design has been proposed as an ”orthogonal” approach that can be
applied to all methodologies proposed so far to cope with the complexity of system design. Contract based
design provides a rigorous scaffolding for verification, analysis and abstraction/refinement. Companion
report RR-8759 proposes a unified treatment of the topic that can help in putting contract-based design in perspective.
This paper complements RR-8759 by further discussing methodological aspects of system design with
contracts in perspective and presenting two application cases.
The first application case illustrates the use of contracts in requirement engineering, an area of system design
where formal methods were scarcely considered, yet are stringently needed. We focus in particular to the
critical design step by which sub-contracts are generated for suppliers from a set of different viewpoints
(specified as contracts) on the global system. We also discuss important issues regarding certification in
requirement engineering, such as consistency, compatibility, and completeness of requirements.
The second example is developed in the context of the Autosar methodology now widely advocated in
the automotive sector. We propose a contract framework to support schedulability analysis, a key step in
Autosar methodology. Our aim differs from the many proposals for compositional schedulability analysis
in that we aim at defining sub-contracts for suppliers, not just performing the analysis by parts—we know
from companion paper RR-8759 that sub-contracting to suppliers differs from a compositional analysis entirely
performed by the OEM. We observe that the methodology advocated by Autosar is in contradiction with
contract based design in that some recommended design steps cannot be refinements. We show how to
circumvent this difficulty by precisely bounding the risk at system integration phase. Another feature of
this application case is the combination of manual reasoning for local properties and use of the formal
contract algebra to lift a collection of local checks to a system wide analysis.
