The total irregularity of a graph
In this note a new measure of irregularity of a graph G is introduced. It is named the total irregularity of a graph and is defined as irr(t)(G) - 1/2 Sigma(u, v is an element of V(G)) vertical bar d(G)(u) - d(G)(v)vertical bar, where d(G)(u) denotes the degree of a vertex u is an element of V(G). All graphs with maximal total irregularity are determined. It is also shown that among all trees of the same order the star has the maximal total irregularity.
