An additive subfamily of enlargements of a maximally monotone operator - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
We introduce a subfamily of additive enlargements of a maximally monotone operator. Our definition is inspired by the early work of Simon Fitzpatrick. These enlargements constitute a subfamily of the family of enlargements introduced by Svaiter. When the operator under consideration is the subdifferential of a convex lower semicontinuous proper function, we prove that some members of the subfamily are smaller than the classical ε-subdifferential enlargement widely used in convex analysis. We also recover the epsilon-subdifferential within the subfamily. Since they are all additive, the enlargements in our subfamily can be seen as structurally closer to the ε-subdifferential enlargement.
BMRT-FINALafterClaudia'scomments.pdf (222.41 Ko) Télécharger le fichier
hal-01180721 , version 1 (29-07-2015)
hal-01180721 , version 2 (30-08-2015)
Regina Burachik, Juan Enrique Martínez-Legaz, Mahboubeh Rezaie, Michel Théra. An additive subfamily of enlargements of a maximally monotone operator. 2015. ⟨hal-01180721v1⟩
287 Consultations
99 Téléchargements
