Mixing Times of Plane Random Rhombus Tilings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2001
We address the question of single flip discrete dynamics in sets of two-dimensional random rhombus tilings with fixed polygonal boundaries. Single flips are local rearrangements of tiles which enable to sample the configuration sets of tilings via Markov chains. We determine the convergence rates of these dynamical processes towards the statistical equilibrium distributions and we demonstrate that the dynamics are rapidly mixing: the ergodic times are polynomial in the number of tiles up to logarithmic corrections. We use an inherent symmetry of tiling sets which enables to decompose them into smaller subsets where a technique from probability theory, the so-called coupling technique, can be applied. We also point out an interesting occurrence in this work of extreme-value statistics, namely Gumbel distributions.
dmAA0101.pdf (210.94 Ko) Télécharger le fichier
hal-01182980 , version 1 (06-08-2015)
Nicolas Destainville. Mixing Times of Plane Random Rhombus Tilings. Discrete Models: Combinatorics, Computation, and Geometry, DM-CCG 2001, 2001, Paris, France. pp.1-22, ⟨10.46298/dmtcs.2300⟩. ⟨hal-01182980⟩
132 Consultations
687 Téléchargements
