Non-Determinism and Nash Equilibria for Sequential Game over Partial Order - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2005
In sequential games of traditional game theory, backward induction guarantees existence of Nash equilibrium by yielding a sub-game perfect equilibrium. But if payoffs range over a partially ordered set instead of the reals, then the backward induction predicate does no longer imply the Nash equilibrium predicate. Non-determinism is a solution: a suitable non-deterministic backward induction function returns a non-deterministic strategy profile which is a non-deterministic Nash equilibrium. The main notions and results in this article are constructive, conceptually simple and formalised in the proof assistant Coq.
dmAF0106.pdf (86.92 Ko) Télécharger le fichier
hal-01183332 , version 1 (12-08-2015)
Stéphane Le Roux. Non-Determinism and Nash Equilibria for Sequential Game over Partial Order. Computational Logic and Applications, CLA '05, 2005, Chambéry, France. pp.77-86, ⟨10.46298/dmtcs.3468⟩. ⟨hal-01183332⟩
99 Consultations
761 Téléchargements
