STS-k: A Multilevel Sparse Triangular Solution Scheme for NUMA Multicores - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2015
We consider techniques to improve the performance of parallel sparse triangular solution on non-uniform memory architecture multicores by extending earlier coloring and level set schemes for single-core multiprocessors. We develop sts-k, where k represents a small number of transformations for latency reduction from increased spatial and temporal locality of data accesses. We propose a graph model of data reuse to inform the development of sts-k and to prove that computing an optimal cost schedule is NP-complete. We observe significant speed-ups with sts-3 on 32-core Intel Westmere-EX and 24-core AMD `MagnyCours' processors. Incremental gains solely from the 3-level transformations in sts-3 for a fixed ordering, correspond to reductions in execution times by factors of 1.4 (Intel) and 1.5 (AMD) for level sets and 2 (Intel) and 2.2 (AMD) for coloring. On average, execution times are reduced by a factor of 6 (Intel) and 4 (AMD) for sts-3 with coloring compared to a reference implementation using level sets.
rr-8763.pdf (1.05 Mo) Télécharger le fichier
hal-01183904 , version 1 (11-08-2015)
  • HAL Id : hal-01183904 , version 1
Humayun Kabir, Joshua Booth, Guillaume Aupy, Anne Benoit, Yves Robert, et al.. STS-k: A Multilevel Sparse Triangular Solution Scheme for NUMA Multicores. [Research Report] RR-8763, Penn State University; ENS Lyon; INRIA. 2015. ⟨hal-01183904⟩
162 Consultations
213 Téléchargements
