Abstract : The problem of finding the convex hull of the intersection points of random lines was studied in Devroye and Toussaint, 1993 and Langerman, Golin and Steiger, 2002, and algorithms with expected linear time were found. We improve the previous results of the model in Devroye and Toussaint, 1993 by giving a universal algorithm for a wider range of distributions.
