Packing triangles in low degree graphs and indifference graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2005
We consider the problems of finding the maximum number of vertex-disjoint triangles (VTP) and edge-disjoint triangles (ETP) in a simple graph. Both problems are NP-hard. The algorithm with the best approximation guarantee known so far for these problems has ratio $3/2 + ɛ$, a result that follows from a more general algorithm for set packing obtained by Hurkens and Schrijver in 1989. We present improvements on the approximation ratio for restricted cases of VTP and ETP that are known to be APX-hard: we give an approximation algorithm for VTP on graphs with maximum degree 4 with ratio slightly less than 1.2, and for ETP on graphs with maximum degree 5 with ratio 4/3. We also present an exact linear-time algorithm for VTP on the class of indifference graphs.
dmAE0150.pdf (184.31 Ko) Télécharger le fichier
hal-01184365 , version 1 (14-08-2015)
Gordana Manić, Yoshiko Wakabayashi. Packing triangles in low degree graphs and indifference graphs. 2005 European Conference on Combinatorics, Graph Theory and Applications (EuroComb '05), 2005, Berlin, Germany. pp.251-256, ⟨10.46298/dmtcs.3408⟩. ⟨hal-01184365⟩
Collections
TDS-MACS
62 Consultations
655 Téléchargements
