Labeling planar graphs with a condition at distance two - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2005
An $L(2,1)$-labeling of a graph is a mapping $c:V(G) \to \{0,\ldots,K\}$ such that the labels assigned to neighboring vertices differ by at least $2$ and the labels of vertices at distance two are different. Griggs and Yeh [SIAM J. Discrete Math. 5 (1992), 586―595] conjectured that every graph $G$ with maximum degree $\Delta$ has an $L(2,1)$-labeling with $K \leq \Delta^2$. We verify the conjecture for planar graphs with maximum degree $\Delta \neq 3$.
dmAE0109.pdf (149.24 Ko) Télécharger le fichier
hal-01184374 , version 1 (14-08-2015)
Peter Bella, Daniel Král, Bojan Mohar, Katarina Quittnerová. Labeling planar graphs with a condition at distance two. 2005 European Conference on Combinatorics, Graph Theory and Applications (EuroComb '05), 2005, Berlin, Germany. pp.41-44, ⟨10.46298/dmtcs.3417⟩. ⟨hal-01184374⟩
Collections
TDS-MACS
98 Consultations
674 Téléchargements
