Conference papers
Acyclic Coloring of Graphs of Maximum Degree $\Delta$
Abstract : An acyclic coloring of a graph $G$ is a coloring of its vertices such that: (i) no two neighbors in $G$ are assigned the same color and (ii) no bicolored cycle can exist in $G$. The acyclic chromatic number of $G$ is the least number of colors necessary to acyclically color $G$, and is denoted by $a(G)$. We show that any graph of maximum degree $\Delta$ has acyclic chromatic number at most $\frac{\Delta (\Delta -1) }{ 2}$ for any $\Delta \geq 5$, and we give an $O(n \Delta^2)$ algorithm to acyclically color any graph of maximum degree $\Delta$ with the above mentioned number of colors. This result is roughly two times better than the best general upper bound known so far, yielding $a(G) \leq \Delta (\Delta -1) +2$. By a deeper study of the case $\Delta =5$, we also show that any graph of maximum degree $5$ can be acyclically colored with at most $9$ colors, and give a linear time algorithm to achieve this bound.
Complete list of metadata
Cited literature [9 references]  Display  Hide  Download
https://hal.inria.fr/hal-01184439
Contributor : Coordination Episciences Iam Connect in order to contact the contributor
Submitted on : Friday, August 14, 2015 - 2:58:57 PM
Last modification on : Saturday, June 25, 2022 - 10:35:51 AM
Long-term archiving on: : Sunday, November 15, 2015 - 11:12:28 AM
File
dmAE0175.pdf
Publisher files allowed on an open archive
Identifiers
Citation
Guillaume Fertin, André Raspaud. Acyclic Coloring of Graphs of Maximum Degree $\Delta$. 2005 European Conference on Combinatorics, Graph Theory and Applications (EuroComb '05), 2005, Berlin, Germany. pp.389-396, ⟨10.46298/dmtcs.3450⟩. ⟨hal-01184439⟩
Share
Metrics
Record views
418
Files downloads
718
