Abstract : Grown simple families of increasing trees are a subclass of increasing trees, which can be constructed by an insertion process. Three such tree families contained in the grown simple families of increasing trees are of particular interest: $\textit{recursive trees}$, $\textit{plane-oriented recursive trees}$ and $\textit{binary increasing trees}$. Here we present a general approach for the analysis of a number of label-based parameters in a random grown simple increasing tree of size $n$ as, e.g., $\textit{the degree of the node labeled j}$, $\textit{the subtree-size of the node labeled j}$, etc. Further we apply the approach to the random variable $X_{n,j,a}$, which counts the number of size-$a$ branches attached to the node labeled $j$ (= subtrees of size $a$ rooted at the children of the node labeled $j$) in a random grown simple increasing tree of size $n$. We can give closed formulæ for the probability distribution and the factorial moments. Furthermore limiting distribution results for $X_{n,j,a}$ are given dependent on the growth behavior of $j=j(n)$ compared to $n$.
