Scale invariance analysis for genetic networks applying homogeneity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Mathematical Biology Année : 2015
Scalability is a property describing the change of the trajectory of a dynamical system under a scaling of the input stimulus and of the initial conditions. Particular cases of scalability include the scale invariance and fold change detection (when the scaling of the input does not influence the system output). In the present paper it is shown that homogeneous systems have this scalability property while locally homogeneous systems approximately possess this property. These facts are used for detecting scale invariance or approximate scalability (far from a steady state) in several biological systems. The results are illustrated by various regulatory networks.
Homogeneity_for_a_class_of_biological_systems_v9.pdf (437.23 Ko) Télécharger le fichier
hal-01185119 , version 1 (19-08-2015)
Emmanuel Bernuau, Denis Efimov, Wilfrid Perruquetti. Scale invariance analysis for genetic networks applying homogeneity. Journal of Mathematical Biology, 2015, 72, pp.1--10. ⟨10.1007/s00285-015-0923-y⟩. ⟨hal-01185119⟩
177 Consultations
134 Téléchargements
