The Size of One-Way Cellular Automata - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2010
Martin Kutrib
  • Fonction : Auteur
  • PersonId : 884118
Andreas Malcher
  • Fonction : Auteur
  • PersonId : 884119
We investigate the descriptional complexity of basic operations on real-time one-way cellular automata with an unbounded as well well as a fixed number of cells. The size of the automata is measured by their number of states. Most of the bounds shown are tight in the order of magnitude, that is, the sizes resulting from the effective constructions given are optimal with respect to worst case complexity. Conversely, these bounds also show the maximal savings of size that can be achieved when a given minimal real-time OCA is decomposed into smaller ones with respect to a given operation. From this point of view the natural problem of whether a decomposition can algorithmically be solved is studied. It turns out that all decomposition problems considered are algorithmically unsolvable. Therefore, a very restricted cellular model is studied in the second part of the paper, namely, real-time one-way cellular automata with a fixed number of cells. These devices are known to capture the regular languages and, thus, all the problems being undecidable for general one-way cellular automata become decidable. It is shown that these decision problems are $\textsf{NLOGSPACE}$-complete and thus share the attractive computational complexity of deterministic finite automata. Furthermore, the state complexity of basic operations for these devices is studied and upper and lower bounds are given.
dmAL0106.pdf (435.03 Ko) Télécharger le fichier
hal-01185494 , version 1 (20-08-2015)
Martin Kutrib, Jonas Lefèvre, Andreas Malcher. The Size of One-Way Cellular Automata. Automata 2010 - 16th Intl. Workshop on CA and DCS, 2010, Nancy, France. pp.71-90, ⟨10.46298/dmtcs.2758⟩. ⟨hal-01185494⟩
317 Consultations
617 Téléchargements
