Stochastic Analysis of the $k$-Server Problem on the Circle - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2010
We consider a stochastic version of the $k$-server problem in which $k$ servers move on a circle to satisfy stochastically generated requests. The requests are independent and identically distributed according to an arbitrary distribution on a circle, which is either discrete or continuous. The cost of serving a request is the distance that a server needs to move to reach the request. The goal is to minimize the steady-state expected cost induced by the requests. We study the performance of a greedy strategy, focusing, in particular, on its convergence properties and the interplay between the discrete and continuous versions of the process.
dmAM0102.pdf (146.18 Ko) Télécharger le fichier
hal-01185590 , version 1 (20-08-2015)
Aris Anagnostopoulos, Clément Dombry, Nadine Guillotin-Plantard, Ioannis Kontoyiannis, Eli Upfal. Stochastic Analysis of the $k$-Server Problem on the Circle. 21st International Meeting on Probabilistic, Combinatorial, and Asymptotic Methods in the Analysis of Algorithms (AofA'10), 2010, Vienna, Austria. pp.21-34, ⟨10.46298/dmtcs.2791⟩. ⟨hal-01185590⟩
346 Consultations
641 Téléchargements
