Virtualization Support for Dynamic Core Library Update - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Dynamically updating language runtime and core libraries such as collections and threading is challenging since the update mechanism uses such libraries at the same time that it modifies them. To tackle this challenge, we present Dynamic Core Library Update (DCU) as an extension of Dynamic Software Update (DSU) and our approach based on a virtualization architecture. Our solution supports the update of core libraries as any other normal library, avoiding the circular dependencies between the updater and the core libraries. Our benchmarks show that there is no evident performance overhead in comparison with a default execution. Finally, we show that our approach can be applied to real life scenario by introducing a critical update inside a web application with 20 simulated concurrent users. Acknowledgments We thank the European Smalltalk User Group for their support (www.esug.org).
Poli15b-Onward-CoreLibrariesHotUpdate.pdf (374.12 Ko) Télécharger le fichier
hal-01185819 , version 1 (01-11-2015)
Copyright (Tous droits réservés)
Guillermo Polito, Stéphane Ducasse, Noury Bouraqadi, Luc Fabresse, Max Mattone. Virtualization Support for Dynamic Core Library Update. Onward!, Oct 2015, Pittsburg, United States. ⟨10.1145/2814228.2814236⟩. ⟨hal-01185819⟩
151 Consultations
145 Téléchargements
