Journal articles
Using finite transducers for describing and synthesising structural time-series constraints
Nicolas Beldiceanu 1, 2 Mats Carlsson 3 Rémi Douence 4 Helmut Simonis 5
2 TASC - Theory, Algorithms and Systems for Constraints
Inria Rennes – Bretagne Atlantique , Département informatique - EMN, LINA - Laboratoire d'Informatique de Nantes Atlantique
4 ASCOLA - Aspect and composition languages
Abstract : We describe a large family of constraints for structural time series by means of function composition. These constraints are on aggregations of features of patterns that occur in a time series, such as the number of its peaks, or the range of its steepest ascent. The patterns and features are usually linked to physical properties of the time series generator, which are important to capture in a constraint model of the system, i.e. a conjunction of constraints that produces similar time series. We formalise the patterns using finite transducers, whose output alphabet corresponds to semantic values that precisely describe the steps for identifying the occurrences of a pattern. Based on that description, we automatically synthesise automata with accumulators, as well as constraint checkers. The description scheme not only unifies the structure of the existing 30 time-series constraints in the Global Constraint Catalogue, but also leads to over 600 new constraints, with more than 100,000 lines of synthesised code.
Complete list of metadatas
https://hal.inria.fr/hal-01186662
Contributor : Contraintes Lina <>
Submitted on : Tuesday, August 25, 2015 - 2:09:17 PM
Last modification on : Tuesday, January 28, 2020 - 12:23:57 PM
Links full text
Identifiers
Citation
Nicolas Beldiceanu, Mats Carlsson, Rémi Douence, Helmut Simonis. Using finite transducers for describing and synthesising structural time-series constraints. Constraints, Springer Verlag, 2015, pp.19. ⟨10.1007/s10601-015-9200-3⟩. ⟨hal-01186662⟩
Share
Metrics
Record views
644
