On the use of H-Matrix Arithmetic in PaStiX: a Preliminary Study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
When solving large sparse linear systems, both the amount of memory needed and the computational cost represent a burden to efficiency. In order to solve larger systems, low-rank strategies are used to reduce the overall complexity of a solver. In this talk, we present a preliminary study of the use of H-Matrix arithmetic in a supernodal solver. We also present a new feature in PaStiX, a reordering strategy to reduce the number of off-diagonal blocks in the symbolic factorization. It allows BLAS kernels to be more efficient, and those ideas could be explored in the context of a low-rank strategy.
Fichier non déposé
hal-01187882 , version 1 (27-08-2015)
  • HAL Id : hal-01187882 , version 1
Mathieu Faverge, Grégoire Pichon, Pierre Ramet, Jean Roman. On the use of H-Matrix Arithmetic in PaStiX: a Preliminary Study. Workshop on Fast Direct Solvers, Jun 2015, Toulouse, France. ⟨hal-01187882⟩
Collections
CNRS INRIA INRIA2
186 Consultations
0 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
