Descriptor Approach for Attitude Estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Alain Kibangou
Hassen Fourati
In this paper, a new modeling and filtering approachfor rigid body attitude estimation is investigated. Incontrast to the current state-of-the art where the process modelisdrivenbygyroscope measurements, weproposeanalternativemodeling formulation where the process model is fed by themagnetometer measurements. The resulting dynamic modeltakes the form of a descriptor system, also known as singularsystem.Basedonthismodelandusingthequaternionformalismwe derive a recursive filter whose performance is validatedthrough numerical and experimental tests.
Fichier non déposé
hal-01188631 , version 1 (31-08-2015)
  • HAL Id : hal-01188631 , version 1
Aida Makni, Alain Kibangou, Hassen Fourati. Descriptor Approach for Attitude Estimation. MSC 2015 - IEEE Multi-Conference on Systems and Control, Sep 2015, Sydney, Australia. ⟨hal-01188631⟩
250 Consultations
0 Téléchargements
