An algorithmic analysis of Flood-It and Free-Flood-It on graph powers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2014
Flood-it is a combinatorial game played on a colored graph G whose aim is to make the graph monochromatic using the minimum number of flooding moves, relatively to a fixed pivot. Free-Flood-it is a variant where the pivot can be freely chosen for each move of the game. The standard versions of Flood-it and Free-Flood-it are played on m ×n grids. In this paper we analyze the behavior of these games when played on other classes of graphs, such as d-boards, powers of cycles and circular grids. We describe polynomial time algorithms to play Flood-it on C2n (the second power of a cycle on n vertices), 2 ×n circular grids, and some types of d-boards (grids with a monochromatic column). We also show that Free-Flood-it is NP-hard on C2n and 2 ×n circular grids.
dmtcs-16-3-16.pdf (391.59 Ko) Télécharger le fichier
hal-01188900 , version 1 (31-08-2015)
Uéverton dos Santos Souza, Fábio Protti, Maise Dantas Da Silva. An algorithmic analysis of Flood-It and Free-Flood-It on graph powers. Discrete Mathematics and Theoretical Computer Science, 2014, Vol. 16 no. 3 (3), pp.279--290. ⟨10.46298/dmtcs.2086⟩. ⟨hal-01188900⟩
Collections
TDS-MACS
271 Consultations
1180 Téléchargements
